timefactor “twin delays”
Home Forums Products Stompboxes timefactor “twin delays”
Viewing 3 reply threads
    • #108611
      hi,
      i'd like to know more about the "twin delays" concept and application (using guitar input 1, to amp output 1).  i.e., correct me if i'm wring but most delays are one delay?  so, how can twin delays be used or what makes it "better" in similar applications as those that only have a single delay?
    • #123307
      badmelonfarmer
        The most famous example I can think of off the top of my head is the way the Edge from U2 uses dual delays.
        1 delay for a single note repeat and the other delay for the dotted 8th.
        there is also a LOT of cool stuff that can be done by using the "Fibonacci" number sequence, check out these videos:-
        http://forum.eventide.com/cs/forums/p/6880/30374.aspx
        The really cool thing about the "Fibonacci" numbers when used with delays is that they do not seem to be as reliant on correct tempo.
        Have fun
      • #123314
        i know music, so BOOM!  got it!
        thx
      • #134413
        badmelonfarmer
          No problem, really recommend playing with the Fibonacci delay times
          F0 F1 F2 F3 F4 F5 F6 F7 F8 F9 F10 F11 F12 F13 F14 F15 F16 F17 F18 F19 F20
          0 1 1 2 3 5 8 13 21 34 55 89 144 233 377 610 987 1597 2584 4181
          6765
          I use 233 and 377 or 377 and 610 the most.
          Have fun.
