Home › Forums › Products › Stompboxes › Timefactor update problem: C++ Runtime Library
March 10, 2010 at 4:46 pm #106942
First time updating my new Timefactor. I have read the sticky at the top of the page and as far as I can tell none apply to me.
The software version currently installed is 2.0.3[2]. I am trying to install 2.4.2[1]
I am running Vista 64 bit.
When trying to download the update (before installing it) I make it through the login/pass screen and the user agreement, but after the Readme I get this:
Assertion Failed!
Program: …EventideUpdate Utilityeventideupdateutility.exe
File: .httpthread.cpp
Line: 475
Expression: !fileName.isEmpty()
For more information on how your program can cause an assertion failure, see the Visual C++ documentation on asserts.
(Press Retry to debug the application – JIT must be enabled)
So yes…I'm confused! I love my Timefactor and can't wait to try the update. Please help me sort this out…thanks!
-AT
March 10, 2010 at 4:55 pm #120120
If you have tried everything under READ THIS –
Problems with Update Utility please contact support@eventide.com -
March 10, 2010 at 5:17 pm #120122
Fixed thank you. Wrong user name. Thanks for twisting my arm to try the sticky solutions
One suggestion: When people accidentally enter the wrong user/pass, how about changing the error message to something simple such as "wrong username or password" instead of all that intimidating programming stuff?
Thanks for your time!
AT
March 11, 2010 at 10:17 pm #131310
There are a number of Update Utility issues related to wrong user names, passwords etc. The fact that it gives you meaningless programmerese is an example of one of these. Apologies – happily you were able to work out the problem in spite of our efforts to confuse you.
Our massive team of programmers is beavering away to fix these and other as yet undiscovered problems. Once they have made some progress we will feed them again and distribute the results of their work.
