Timefactor w/ MIDI controller question
Home Forums Products Stompboxes Timefactor w/ MIDI controller question
    • #112571
      I am on the verge of grabbing a MIDI controller to operate my whole board, but have a concern about how I want it to function.
      I currently use my Timefactor as a MIDI clock that sends to every other time-based effect.  Since the TF will likely have to be set to MIDI Thru to work with a controller, will it continue to send MIDI clock to everything else?
    • #127787
        If you set it to THRU, it won't send anything, only pass thru received stuff.
         It can receive from a controller and also send MIDIclock, but it won't then pass thru the controller MIDI.
        To do the second, you will need a MIDI merge box (see MIDI Solutions, etc)..
