Home › Forums › Products › Stompboxes › TimeFactor won’t bank up after update
March 7, 2011 at 1:28 pm #107693
I updated a few weeks ago and now the TimeFactor won't bank up. It's not the switch as the tap mode works perfectly, but when I put it back into bank mode, nothing. The presets work, but I can't bank. If I save into slot 2:2, then I can utilize the extra banks, but that's it. Any ideas as to what's going on, or more importantly how to fix it?
March 7, 2011 at 6:03 pm #121675
Hello cousin Mike !
Not quite sure what you are saying. What do you mean by "bank up" ?
March 7, 2011 at 6:10 pm #121677
I can't change banks with the footswitch. I'm stuck to using 2 presets, 1:1 and 1:2.
March 7, 2011 at 7:14 pm #132899
did you see how many banks are active in setup
Utility–> Banks–> L# … H#
Mine is setup to L1….H50 and I get all 50 banks.
hope this helps
A
March 8, 2011 at 3:46 am #132904
Just tried that. It worked!!! It was letting me save in the other banks but maybe they were still inactive? I have no idea, but it works! 🙂 Now if only Eventide could build in the ability to bank down…
March 8, 2011 at 1:00 pm #132906
You can bank down with an aux switch. read the post for the link below
