Toggling between A & B on H90
Home Forums Products Stompboxes Toggling between A & B on H90
    • #172309
      Boynigel
        Does anyone know if it’s possible to program the H90 to toggle between effects A&B with just one foot switch?  obviously i could step on two switches at once, simultaneously turning one on, and the other off, but that can be clumsy…at least for me.
      • #172310
        joecozzi
          I’m assuming you want to control Preset A and Preset B bypass states within the same Program. For this to work, you’ll have to use an external aux switch and store the Program with one preset active and the other in a bypassed state. Then in Global – Pedal Control, map “A act/byp” and “B act/byp” to the same aux switch. With one press of this aux switch, you can seemingly toggle active states for both presets.
        • #172311
          fiddlercrabseason
            You can also set up a hotswitch to do that.  Start with output gain of A at 0, output gain of B at -60, then program the hotswitch to pull A to -60, and push B to 0.  Haven’t actually done it, so don’t know if there’s any lag, but it’s possible.
