Trying to create a repeat or delay setting that will repeat back a preset set length when the aux switch is engaged
Home › Forums › Products › Stompboxes › Trying to create a repeat or delay setting that will repeat back a preset set length when the aux switch is engaged
Viewing 3 reply threads
    • #115394
      davebrubaker
        As an example let’s say I set the repeat to 1/4 notes and hold the aux switch down so I get 3 rerpeats at the original volume. Next time I might hold the switch down to get 6 repeats, or what ever I choose. The length of the sample is determined by the tempo and repeat seetting. How many times it repeats is determined by the hold switch. This way the timing is always consistant and in tempo. The footswitch simply controls the number of repeats for as long as you hold it down. It would be ideal if the repeats didn’t decay.
        I’m assuming this is possible. Any suggestions? Thanks in advance for your thoughts.
      • #152190
          Off the top of my head, I’m thinking the UltraTap algorithm (MultiTap is a fixed 5 repeats).
          https://www.eventideaudio.com/products/algorithms/ultratap
          Ignore & zero out all of the controls except MIX, LENGTH, & TAPS.  Set TEMPO = ON.
          Adjust TAPS to the maximum amount of repeats you’ll ever want.  Divide that number of repeats into the overall delay LENGTH, for 1/4 Note on each repeat.  Tie the aux switch to MIX, and momentarily shift from a 0 value to 50 (or whatever MIX delay level is appropriate).
        • #152191
          bohan
            davebrubaker wrote:
            I'm assuming this is possible. Any suggestions? Thanks in advance for your thoughts.
            Are you talking about H9 or TimeFactor? On TimeFactor, you can use the middle footswitch to repeat the delay. On H9, you can map your aux switch to "Performance Switch (aka Middle Footswitch)". You can do the mapping on the unit or in H9 Control (Pedal Settings -> Aux Switch Mappings)
          • #152203
            davebrubaker
              Thanks for the reply guys. Looking forward to giving this a try. Probably won’t have a chance to dig into it until the weekend. I’ll let you know how it goes.
