Home › Forums › Products › Stompboxes › Tuner on/off via midi ( not toggle)
- This topic has 4 replies, 2 voices, and was last updated 1 week, 6 days ago by
Trulsux.
September 28, 2026 at 12:13 pm #202513
Is there a way to have Tuner on and off Cc <span style=”font-size: inherit;”>messages via midi?</span>
<span style=”font-size: inherit;”>I have the ”toggle” programmed on one of my midiswitches but I want to return to a preset without first turning the tuner off on that switch….i.e programmming a ”Tuner off” on my presets </span>
<span style=”font-size: inherit;”>cheers/</span>
<span style=”font-size: inherit;”>Truls</span>
<span style=”font-size: inherit;”> </span>
September 28, 2026 at 3:51 pm #202611
The only option is to toggle the tuner on/off via the MIDI CC. Sending a CC value of 64 or higher toggles the tuner on/off.
Can you please elaborate? What do you mean by “return to a preset”?
September 28, 2026 at 4:22 pm #202612
Hi!
If the only option to turn on/off the tuner via midi cc is toggle then I won’t be able to use it as I want..
I ’m new to the H9 (ver 2) but have programmed one of the switches on my midiswitcher to turn the tuner on/ off no problem ….( toggle)
But having a CC for turning off the tuner ( not toggle) I would be able to have that CC on all my presets i.e saving a push of a button everytime I use the tuner as I first have to turn off the tuner and then choose the preset again…..or two if I want to go to a different preset than the one I was on when engaging the tuner…
I had this setup on my Fractal VP4 and it worked like a charm …
September 29, 2026 at 9:37 am #202676
Thanks for clarifying.
Sorry thats not possible with the current MIDI implementation for the Tuner, but we may be able to add this in a future update.
September 29, 2026 at 9:42 am #202677
Thanks,
That would be great, maybe I’m not the only one not liking Toggle😃
cheers/
Truls
