Turn on the tuner with Aux switch
Home › Forums › Products › Stompboxes › Turn on the tuner with Aux switch
    • #167808
      peaceonu
        I have connected a aux switch to Exp/Ctl 1 for turning the tuner on as I don’t like to step on two switches at the same time.
        but I don’t know how to assign the tuner to the aux switch.
        If there’s anyone who know, please let me know.
      • #167809
        brockstar
          Press “programs and routing” and hold it for like 2 seconds and system menu will show up
          Make sure global is highlighted and use the “select” turning knob and turn until you’re on the screen that shows global – pedal ctl
          Turn parameter until you see “tuner”
          turn ctl source and set it with the appropriate sw 1, sw 2 etc.. which ever one your aux switch is in.
          However if you haven’t, it made be good idea to go to system again and I/O section and use “select” knob and scroll until you see exp & aux and set up your exp or aux stuff there and calibrate if needed.
          • #167819
            peaceonu
              I really appreciate your reply
              To use EXP/CTL 1 as SW1, do I have to assign it to SW1 also? if then, would you please let me know how to do that also?
              I know H90’s interction is much easier than H9, but it is still difficult for me to use.
              Thank you again
