Home › Forums › Products › Stompboxes › Two H9’s and one Aux Switch for changing presets
January 13, 2016 at 11:38 pm #113163
I’m going to be running two H9’s and was wondering if you can use one aux switch to make both h9’s change presets simultaneously? I know you can control tap tempo on both H9’s from one aux switch by hooking up a midi cable between the two H9’s and then setting master / slave, etc but not sure about presets (up / down). I would assume you could do the same for preset switching
I don’t know about aux switches, but you can control one H9 with another via MIDI, so you could “pair” presets via MIDI messages.
January 17, 2016 at 11:02 pm #142178
You can connect one aux switch to two H9's by using a suitable Y-lead, as long as you avoid ground loops.
September 15, 2019 at 5:00 pm #152722nickrose wrote:
You can connect one aux switch to two H9’s by using a suitable Y-lead, as long as you avoid ground loops.
IF I DID THAT, WITH THAT AUX SWITCH AND TWO H9, COULD I HAVE THE DELAY TRAILS WORKING GOOD ?
