Two questions about the TIme Factor
Home Forums Products Stompboxes Two questions about the TIme Factor
    • #107331
      I'm thinking about buying a Time Factor and I was wondering about two things:
      – The delay is limited to 3 sec., does it mean that if I turn the tempo on, the BPM can't be set below 80 BPM? I mean, if I choose a 60 BPM tempo and a delay corresponding to a whole note, then the delay will go up to 4 sec. Is this possible?
      -Can I use my MPC to adjust the tempo's TF?
      (I read that there was some troubles with the synchronisation, when the TF is in a slave mode)
      Thank you and pardon my english!
    • #120872
        The delay is indeed limited to 3 seconds – this means it cannot be increased beyond this.
        Not sure what an MPC is. TF will receive MIDIclock, but there have been some complaints that it will not handle a very bad signal.
      • #120875
        Doug Wellington
          Akai MPC – drum machine/sequencer/sampler
          http://en.wikipedia.org/wiki/Music_Production_Center
