UI state inconsistency in Control 2.9.4 with sculpt algorithm
Home Forums Products Stompboxes UI state inconsistency in Control 2.9.4 with sculpt algorithm
    • #114683
      skywriter
      When in the ’presets’ screen using Sculpt Algorithm. Every time you select ‘back’ or ‘EQ curves’ in any view mode that displays the Algorithm column. The Algorithm column display will reset to the top of its list regardless of ‘By Type’, ‘By Use’, ‘By Name’, or ‘By Date’. All the other Algorithms that have two modes of control, preserve state of the Algorithm column, so this should be a bug.
      Haven’t used my H9’s in a while, and just loaded 2.9.4 yesterday and found it right away.
    • #148879
      gkellum
      You're right. It does do this, and the same thing doesn't happen in Resonator for example.  Thanks for the feedback.  We'll fix it.
