Update Utility Login Problem!
Home Forums Products Stompboxes Update Utility Login Problem!
Viewing 4 reply threads
    • #107604
      I can log into the site just fine but I get an error message when I try to log into the update utility.
    • #121485
        The error message is complaining about lack of a user name. Presumably it is unhappy with the one you are giving it, although you say you could log into the web site.
        You should probably contact support@eventide.com, giving your unit serial number and user name.
      • #121486
        There is a space in my username which may be what's confusing the login.
      • #132682
          could be – doesn't like spaces or other non-alphanumeric characters. You'll have to contact support to get it changed.
        • #132684
          I changed my username to play nice with the update utility.  Not an easy task.
          Now I'm updated 🙂
