USB setup between Factor/H9 and iPad (2018)
Home › Forums › Products › Stompboxes › USB setup between Factor/H9 and iPad (2018)
Viewing 3 reply threads
    • #114896
      wilkinsi
        I only recently bought myself an iPad. When connecting say, the Space pedal to an iPad, it requires the Camera USB connection adapter. Is there some kind of setup/configuration I must go through in order to make H9 Control work with the Space pedal?
      • #149917
        gkellum
          No, if you connect your Space with the camera connection kit to the iPad, it should automatically be recognized by the iPad as a MIDI device, and H9 Control should just find it when it launches.
        • #149918
          nsanchez
          • #149920
            wilkinsi
              Excellent. Thanks!
              (I’m somewhat embarrased to say I bought the basic 2018 iPad, not either of the two Pro versions…)
