Using balanced cables with H9?
Home › Forums › Products › Stompboxes › Using balanced cables with H9?
    • #114365
      M-Goldie
        I have my H9 connected as an outboard line level send/return fx unit with my DAW. My I’m using balanced jacks in & out to my UAD Apollo. It works fine but I wanted to check this was ok as I think the connections on the H9 are unbalanced?
      • #147170
          The H9 connections are unbalanced, but if you connect a balanced TRS cable, it will be automatically unbalanced and should work fine.
        • #147171
          M-Goldie
            Thanks for the clarification 🙂
