Using h9 looper for audio playback
Home Forums Products Stompboxes Using h9 looper for audio playback
    • #112803
      Jop vS
        Hi, I’ve got a quick question, and was hoping someone could help me out.
        For some tracks I was hoping to use one of my h9’s to play some audio samples. I now use a boss RC-50 for this purpose alone, so if i could remove this from my setup it would save quite a bit of space. Using the pre-post option, I could even send it to a separate DI box.
        Using the looper algorithm, can you include the recorded audio when saving a preset? I haven’t been able to do so.
        Fingers crossed!
        Regards, Jop
      • #140337
        Unfortunately you can not. Unless there is some kind of “easter egg” that I’m not aware of.
        I use a USB digital recorder and just put it on my microphonic neck pickup to loop a sample that I later manipulate by playing with the Looper controls.
      • #140339
        Jop vS
          Too bad, would be a great feature for me. Thanks for the reply!
