using Space as midi clock with tap-t help/ideas/solutions?
Home Forums Products Stompboxes using Space as midi clock with tap-t help/ideas/solutions?
Viewing 0 reply threads
    • #108192
      jborges
        I am redoing my pedal board and I wanted to use the space as the master midi clock to send to two other pedals.   I have no problem setting it up where it sends the clock bpm to the other pedals.  My issue is this:
            I have a 3button aux switch hooked to the Space and I use that to set tempo.  When the space has a patch where the tempo is on and needed, it all works great.  When I have a patch without   the tempo turned on is where the problem is.   When it is off the tap function controls the decay or pre/delay.  So if I want any pedals after the Space to get the correct bpm it ends up changing decay time or pre delay while sending the bpm/tempo ,   which I do not want it to do.     I was only wanting it to send clock info to the other pedals.  Is there a way to turn that off or a work around?
          If I put a timefactor as midi clock master it all works fine.  I was wanting to take the TF off the  board and use it on a different one.  So that is the reason for not just using the timefactor first inline….
        any ideas or workarounds?
