Utopia Expression Pedal by rocktron
Home Forums Products Stompboxes Utopia Expression Pedal by rocktron
Viewing 0 reply threads
    • #107876
      Hi ,
      I was wondering if anyone here can confirm that the Utopia Expression Pedal will work properly with the Modfactor, and or the Timefactor pedals.
      http://www.rocktron.com/products/controllers/utopiaexpressionpedal/
      Heres an excerpt
      The Utopia Expression Pedal is a multi-function pedal that can be used
      both as a volume pedal (with smooth volume transitions) and as an
      expression pedal with a large variety of processors and MIDI
      controllable equipment.
      Use a simple stereo to stereo cable for expression connection, minimizing cable use on stage.
      The expression jack accepts a ¼" stereo RTS cable and lets
      you plug into the expression port in your MIDI footcontroller or the
      expression port in your MIDI controllable device and thus operate the
      Utopia Expression as a MIDI expression pedal.
      Kind regards
      Patrick
