October 26, 2009 at 3:16 pm #106573
I've installed the full release yesterday.
It seems to work correctly, however I've got some issues with preset #494 I already used with V3.51.
Indeed when I used this preset (V3.51) the sound was beautiful, lovely ; with V4.0 installed, it sounds totally wierd & awful
even if I try to change settings.What happened there ?
Furthermore, I met some difficulties too with other presets like # 800 Chors'n'Echo…
When I load the preset there's no sound until I change the delay level which is automatically set @ -100 dB.
Is that normal ?
October 26, 2009 at 3:46 pm #119332
hi archaos
I have just tested the 2 presets and they work fine. No issues.
Do you have anything (MIDI CC/pedal/footswitches) patched to any system/preset parameters that may interfere with how these 2 presets work?
Are all connections properly made?
I
October 26, 2009 at 5:01 pm #119334
Argh !
That's worrying.Actually I have an expresion pedal (BOSS FV-500) connected to the pedal #2 input, but it totally works fine. All connections are OK.
When I used the V4.0B, the presets sound correctly too, as before (V3.51).
I add I have already re-install the full release & the issues remain…
Should I use the V4.0B instead ?
October 26, 2009 at 5:16 pm #130452
No, you should be using the official latest release.
Have you executed a CLEAR SETUP on the unit's prompt to do it, after V4.0 installation?
You can still do it by powering on the unit while holding the SETUP key.
I
October 26, 2009 at 5:28 pm #130453
Thanx for that quick answer !
I'll try your suggestion as soon I get back.
October 26, 2009 at 6:38 pm #130454
I've just executed a CLEAR SETUP & everything is OK, now.
Thanx a lot, Italo !
October 26, 2009 at 7:18 pm #130457
Mighty!
enjoy!
I
