Volume Change with PF in Relay Mode
Home › Forums › Products › Stompboxes › Volume Change with PF in Relay Mode
Viewing 3 reply threads
    • #108015
      I am running the PF through my effects loop in my Soldano Decatone. The effects are awesome; however, in relay mode the overall volume out of my amp decreases when the effect is engaged. When it is bypassed the amp gets significantly louder. If I change the bypass function to DSP this problem goes away but the tone of my amp gets sacrificed (lower output and more nasally mid-range). Is there anyway to balance the volume output when in relay mode so I can maintain the tone of my Soldano?
    • #122454
      achaput
        New in V3 there is an Output Volume adjustment for each preset. This should help with your issue.
        -Alan
      • #122455
        achaput
          You can find out more V3 here.
        • #122456
          Awesome! thanks for the help.
