Vsig question
Home Forums Products Vsig and Preset Development Vsig question
Viewing 4 reply threads
    • #107134
      razo1
      What is wrong with the connection to the Frequency mod input in this patch: why won't the output of 'Peak' modulate the filter frequency?
      Thanks, Ole
    • #120515
      It works, it's just that the effect is rather subtle, and very dependent on the control settings and source material.
      Try the following values with full range source material and you'll get the idea .. you won't like it, but you'll hear it working.
      Freq 100    Mod 20000    Q 10
      Attack 0.5    Decay 0    Select 1
    • #120516
      razo1
      Thanks. I will try if it possible to get 'analoge sound' from some of the other filter types.
    • #131730
      razo1
      Are there any tricks to make it sound more like a classical analog envelope filter?
    • #131731
      razo1:
      I would suggest you use the ADSR module to generate the envelope – after this it is mainly a matter of tuning.
