wet/dry control when insert is active – routing matrix one day?
Home › Forums › Products › Stompboxes › wet/dry control when insert is active – routing matrix one day?
Viewing 0 reply threads
    • #200605
      unguitar
        As an extension of this thread: https://www.eventideaudio.com/forums/topic/h90-insert-bypass-m/
        I also suggest to allow wet/dry mix control when inserts are in the routing path. When there’s an insert active (in my case insert 1 before the processing blocks), the program mix doesn’t work, which is quite weird.
        Given the level of evolution that the H90 platform has reached I would expect to see an open routing matrix soon. This would make a clever use of the available physical connections, allowing merging multiple inputs and splitting multiple outputs.
        When I look at the H90 beside my H8000 (which has an extensive routing flexibility) I always think this feature is just around the corner, and I can’t wait 🙂
