Wet/dry with outboard pedal insert
Home Forums Products Stompboxes Wet/dry with outboard pedal insert
    • #173554
      Mr. Mushroom
        How would the routing work if I wanted to have a wet/dry set up, and also use an insert? For example:
        Having a totally dry signal, and then the wet signal using an outboard pedal in between the presets?
        I’m thinking:
        guitar -> input 1
        output 3 -> outboard pedal -> input 3
        output 1 -> wet amp
        output 4 -> dry amp
        The hope here is that for internal routing on the H90, insert 1 is the outboard pedal and can be placed before, between or after both presets being run in series, and insert 2 would be an unprocessed signal that can be taped before the presets or insert 1, to feed a dry signal.
      • #173555
        joecozzi
          You might find this explanation useful. Go to 8:58 https://youtu.be/0G_WtfUatSc
