what midi foot controller ?????
Home › Forums › Products › Stompboxes › what midi foot controller ?????
Viewing 3 reply threads
    • #111374
      Hi, I have the time factor and the space pedal and a Marshall JVM. Any suggestions on which midi foot controller works best?
      Jeff
    • #140146
      Jeff
      There’s no best.
      But I recommend the Liquid Foot products.
    • #140166
      KCStratman
        The Mission Electronics EP-25K works great with the Factor stompboxes and the H9. It comes in the classic crybaby metal housing if you like that style and is available with dual outputs to operate two units at once if desired.
        • #140254
          teabandito
            What is the reason for the dedicated switches to every H9? Isn’t it easier to control them with on switch via midi connection?
        • #140188
          I have used the behringer fcb 1010.  It works great.  Takes a few minutes to figure out programming ccs for the fcb 1010.
          • #140243
            kmeals9898
              For the Behringer FCB1010 the expression pedals are assignable too with the H-9?
            • #140248
                You can assign each pedal independently for min & max value range and MIDI CC number.  That’s for each of the 100 switch / FCB 1010 preset positions [10 x 10 banks].  The switch can also transmit up to 5 Program Changes, 2 static MIDI CC values (or one alternating set of on/off MIDI CC values), and a MIDI Note value at v=64.  Up to 10 MIDI Channels [one for each message type: PG 1-5, CC 1-2, EXP A-B, and Note] are set globally across the 100 presets.
                One undocumented feature is that Program Change #5 is transmitted after the MIDI CC messages.  This doesn’t apply to the H9, but it allows you to change banks of 128 Program Changes on some devices.  There are many more features added if you install the UnO chip.  Mine is a stock setup.  Either way, do yourself a favor & download one of the 3rd-party free editors.
