Will ‘pancake’ or Right Angle Flat style connectors fit side by side on the H9?
Home › Forums › Products › Stompboxes › Will ‘pancake’ or Right Angle Flat style connectors fit side by side on the H9?
    • #146425
      jgoldbach
        You can use a pancake connector for every other jack only. For instance, input (1) and output (1) and expression, if you wish. They'll run semi-parallel to the floor but not completely, if that makes sense. So if you're running mono, no worries. On my small board I run mono and use the Reverb.com patch cables on my H9 with no problem. They have the same connector as the link you reference.
        FWIW, on my larger pedal board I run pre/post (which requires both input and output jacks) and an OX9 in the expression jack, so I use the George L cables with their right angle connectors. Works very well. Hope this helps.
        • #146433
          cljfford
            Thank you for your reply!
            jgoldbach wrote:
            You can use a pancake connector for every other jack only. …
        • #114171
          cljfford
            I checked the stated measurments of the connectors below and don’t think they’ll fit but am wondering if anyone has tried it for real.
            https://www.redco.com/Redco-Right-Angle-Flat-TS.html
