Home › Forums › Products › Rackmount › Sound design on the Eclipse : New strategies › Reply To: Sound design on the Eclipse : New strategies
#116773
 there is no cool effect without a sound source in mind!
Idea
So many sounds in the real world can be processed to get amazing new stuff.
Real life sounds…that's what I'm talking about.
You can process them thru resonators and/or ring modulation to have tuned results.
A scratch on a rough surface or on muted gr/bass string, going thru multitap delays is a sonic universe.
Once you have sonic sources on your computer, you can try fx parameters modulation w/CC; if you have a way to randomize these…it's cool. Or have lfos sweeping CCs at different speeds (still in your computer if software allows…the H_family tides allow this internally_w/Vsig brain action!!!). Beware of extreme values for parameters that can cause "problems" like a feedback at %.
Chaining FX
-put a modfilter after reverb
-put ringmod after reverb and let a long tail ring thru the wild thing
-put distortion after delays
-..try it after reverb too
-kill dry sounds..and only listen to processed deformations
-try using a mixer with different fx units on separate Aux Sends/Returns; then send an fx to another, and to another…and maybe try to loop it back to itself after other processes, with moderation on levels as feedback may occur
-go to the beach!
I
