Home › Forums › Products › Rackmount › ONE MORE BETA BUILD! V3.5B3 posted › Reply To: ONE MORE BETA BUILD! V3.5B3 posted
#116856
synthtrumpet
    Installed 3.5B3. All indications were that the code took.
    After reboot, did not have any input signal  level indication
    on the meter led.(using analog in).
    Output from Eclipse is nothing but noise.
    Did a reinstall of OS 3.5B3 and noticed I do not get a CLEAR SETUP
    request after intstall. I do get PROGRAMMING COMPLETED,
    CYCLE POWER.
    As you suggested in your install notes, I did a CLEAR SETUP
    by cycling power with SETUP key pressed and held.
    When prompted I reply YES to the RETURN TO
    FACTORY DEFAULTS.
    The Eclipse is still not working right. No input Signal level indication
    plus noisey output
    Thanks
    Jim
