Home › Forums › Products › Rackmount › ADAT port daisy chain?? › Reply To: ADAT port daisy chain??
#116989
     The Eclipse can be set up to put its two output channels on any of the 8 ADAT channels, leaving the other 6 channels either muted or unchanged. It can also receive its input from any of the ADAT channels.
     This means that you can daisy chain the ADAT through the Eclipse, if I understand you correctly. You would probably want to use Wordclock as the sync source.
     See page 27 of the Eclipse Manual for more information.
