Home › Forums › Products › Rackmount › How many effects can you use at once? › Reply To: How many effects can you use at once?
#116999
akjl4
    Oh yeah sorry, I am refering to the H8000FW. I'm not sure how the rounting works, the manual says each dsp has 8ins and outs. So in laymans terms does this mean each dsp can process for instance, 4 stereo tracks with a single algorithm processing them? So if you had the 4 stereo tracks going through both dsps 2 algorithms is the most that you can route across the channels? Or am I missing something and is it possible to run more algorithms at once.
    Thanks, Alvin
