Home Forums Products Rackmount gaintrim control not responding Reply To: gaintrim control not responding
#117093
davros_clone
Hi Italo!
I did the CLEAR SETUP, but still no gaintrim response. Will it actually add gain to a digital input or only to analogue? I'm quite sure it was working when using my s/pdif connection which I've used 98% of the time. So then I turned up my preamp master volume up to about 6 which I normaly only run on 2 and then turned the Eventides analogue out down to about -17db so it was'nt too loud. I used this method to bring the LEDs up about 5 notches. I can hear more detail and substance in the sound now.
Is this the best way to use the Eventide and did you mean the uppermost LED lights up as 0db when using a digital input? Maybe I can get away with not using a gaintrim. Thank you,
Tim.
