Home Forums Products Rackmount Bought secondhand H7600, startup problems Reply To: Bought secondhand H7600, startup problems
#117257
Hi Morten
(from DK?) try powering on the "beast" and PRESS & HOLD the 8 key when you read H7600 on the display. You'll be prompted to reinitialize (loose all stored info) the unit. Press the YES soft key. this will reset the unit as it should, after an used purchase and probably a shipment.
Congrats!
