Home Forums Products Rackmount program change, mapping, etc Reply To: program change, mapping, etc
#117355
I am not really any farther after a good bit of time spent. When you say midi maps should not be a problem, I am not sure what that means. I guess since I do not know how to do this it seems to be a problem to me. Do you have any ideas about what to do to make this work, maybe with a step by step plan?
All of the other gear in the rig changes fine except the eclipse which makes me think it is the problem. I have tried moving the midi start number around for the footcontroller but that does not seem to do anything, the numbers are still off. Changing which map you use does not match numbers it just starts them somewhere else and they are off at that point.
I thought I remember reading about a new update to the eclipse, will that give any quicker load time or fix any of the things I am asking about?
