Home › Forums › Products › Rackmount › Error loading Algorithm #0! › Reply To: Error loading Algorithm #0!
April 28, 2008 at 9:56 am
#117441
Hi Gerry
you should try reinitializing the unit to factory defaults, using the full erase/reinit method. It will erase your presets, if you have creted/stored any.
Power the unit on w/the 8 key pressed & held. Follow the instructions on the display.
You may also want to upgrade your unit as it must be on a very old OS version. Shortly we'll be releasing V3.5. You need to register your unit and creat an account on our website to get the new OS.
all the best
I
