Home › Forums › Products › Rackmount › revolution of reverbs › Reply To: revolution of reverbs
#117449
That's exactly what it does…a convolution reverb 'copy' the impulse response of the place where the signal is played..it means that you can use this instrument in many other ways…to give you a very stupid example:if you play the signal with a pillow in front of the speakers and then create the relative impulse,the 'reverb' created will simulate the playing of the source you would have chosen like it was played throught a pillow ,all with a nowhereelse realism.Use your imagination with the h8000/VSIG possibilities…
