Home › Forums › Products › Rackmount › 1 question before an order (7600 or 8000FW ?) › Reply To: 1 question before an order (7600 or 8000FW ?)
#117496
Bibi
you should go for an H8000Fw, not only because Fripp uses 2 of them….but also because you gat over 4 minutes looping with an H8K….. and using one dsp for looping and the other to process loops AND your own direct sound….well….. that makes A LOT of difference! Besides that…the H7600 is more expensive than the 8000 if you consider the second is more than twiv?ce the power and all its extra features.
I went for Orville over the DSP7500 back then….being a looper.
cheers
I
Idea
