Home Forums Products Rackmount H8000 not recognizing EVE/NET remote Reply To: H8000 not recognizing EVE/NET remote
#117562
    The "EVE/NET present" message just means that the H8000 has detected its own EVE/NET hardware. This is good, but there is more …
    There are a number of reasons why the H8000 may not be seeing the remote. See the EVE/Net User Manual for more information and to understand the notes below.
    1) Most likely is that the "unit", "mode" and especially "range" parameters are set incorrectly. The  "unit" and "range" parameters need to be the same for both the remote and the H8000 .
    2) Does the remote show any life/lights at all ? If not, check the fuse on the H8000 motherboard near the EVE/Net socket which supplies power to the remote. Also in this case, check the ground jumper J2802.
    3) Check that the termination jumper J2803 is installed correctly on the H8000 motherboard.
    4) If none of the above resolve the issue, their may be a hardware problem, but this is uncommon.
