Home Forums Products Rackmount automating patch parameters stuck at 99.3% Reply To: automating patch parameters stuck at 99.3%
#117572
 Hi Siem
I moved your posting into the Harmonizer support folder, as it's more pertinent to it than to Vsig.
Instead of using the MIDI capture, I find my solution by selecting Mode:MIDI single, then either using the MIDI Capture again or simply by manually choose the CC# in the "con" field, showing CC numbers. The MIDI Single assignment works in a more smooth way.
Please try!
best
