Home › Forums › Products › Rackmount › Eclipse V3.5 Block bypass externals – problems › Reply To: Eclipse V3.5 Block bypass externals – problems
June 16, 2008 at 8:46 am
#117591
Hi Mr.Clean
our units need to see a CC value transition between 63 and 64 to activate the change of status (OFF/ON).
In other words, a CC has a 128 steps range; the first half range, 1>63, won't change the current status of a parameter. As soon as you hit 64 the status will change.
If a parameter is OFF, the next time you hit 64 it will change to ON..and the next time a value of 64 is reached, it will get back to OFF.
Simply program your pedalboard to send the CC with value equal or higher than 64 to activate a BYPASS status.
best
I
