Home Forums Products Rackmount Latency of FW Reply To: Latency of FW
#117621
     It's essentially a matter of the buffer size and the sample rate.
    For example: using 512 byte buffers at 96kHz will introduce an each-way delay of 512/96000 =  5.3mS.
    The internal processing in the H8000FW will add la few hundred microseconds beyond this – the buffer size is the determining factor.
