Latency of FW
Home › Forums › Products › Rackmount › Latency of FW
    • #105691
      akjl4
        Is there a way to figure out the amount of samples/seconds of latency that is introduced while using the h8000 firewire routing? For instance I have downloaded the expert sleepers latency fixer, so if I can figure out the latency of my system I can eliminate the latency of my system while mixing.
      • #117621
           It's essentially a matter of the buffer size and the sample rate.
          For example: using 512 byte buffers at 96kHz will introduce an each-way delay of 512/96000 =  5.3mS.
          The internal processing in the H8000FW will add la few hundred microseconds beyond this – the buffer size is the determining factor.
