Home Forums Products Rackmount New Eclipse owner-preamp recommendation Reply To: New Eclipse owner-preamp recommendation
#117650
tacman77
     I had a cheap mic pre with a 12ax7 tube in it that I started using for a guitar preamp. It sounded a lot better when I got into buying vintage tubes for it. You can switch tube types within the 12xxx family. I found using a 12au7 Mullard tube made in the 50's was a good clean preamp.
    I bought a Hafler T2 preamp off ebay that uses 2 tubes, one for a clean channel and 1 for a distortion channel.
    So basically I'm recommending any real tube preamp and learn about the different tubes and how they sound (by buying them- school of hard knocks).
    I have modern modelers but a lot of the effects on the Eclipse need a clean guitar sound to be heard properly.
    Also give any quality mic pre's you have access to a try.
