Home › Forums › Products › Rackmount › New Eclipse owner-preamp recommendation › Reply To: New Eclipse owner-preamp recommendation
July 14, 2008 at 5:18 am
#117677
Hi, I use a Pod Proxt and a new Pod X3 Live. Both cool units, but the presets are dreadful. You need to spend time setting up the unit, especially the cab simulators. I have found to get consistency of tone its best to stick to the same cab and mic settings for the amps you use (in my case a 4@12 Vintage 30, with on access Sm57 and no room). Also I have found the Eclipse is easier to set up in the POD's fx loop in series, with the Eclipse on 100% wet. You then adjust each Eclipse preset to mix / level you want. cheers
