Home › Forums › Products › Rackmount › Small delay › Reply To: Small delay
July 24, 2008 at 12:10 pm
#117705
Hi Yannis
most presets do not have the dry signal; this can be easily aded via the system wet/dry mix. Generally pro_setups use time domain fx in parallel.
You can also add a dry signal by:
-adding an I to O direct connection in the routing scheme
-adding a mixer in the algorithm (Vsigfile).
all the best
I
