Home › Forums › Products › Rackmount › H8000 Balanced to unbalanced cabling › Reply To: H8000 Balanced to unbalanced cabling
August 12, 2008 at 10:22 am
#117754
Hi Kevin
Eventides use XLRs for balanced AND unbalanced +4 dB line level signals OR 1/4" jacks for unbalanced -10/-20 dB instrument level.
Mesa Boogie FX loops run at +4 dB, as a real fx loop should.
Then you must use all XLRs on your H8000, keeping balnced the Eventide side of the cables and unbalancing the Mesa side.
If you check our FAQ on the web site you'll find accurate documentation on how to wire these units. Have a qualified technician doing the job for you.
All the best
I
