Home › Forums › Products › Rackmount › Inputs on the H8000 Question › Reply To: Inputs on the H8000 Question
#117762
ThreeFingersOfLove
    Open the patch you are using with the VSig editor and make changes to it, for instance you can disable the first input coming from the AD converter. You will probably need to make changes to the first output, something like a mixer maybe.
    Regards,
    Yannis
