Home › Forums › Products › Rackmount › 7 Pin MIDI In? › Reply To: 7 Pin MIDI In?
August 18, 2008 at 1:50 pm
#117776
The extra two pins are so you can power a pedel board.
You connect the units wall wart to the back of the eclipse and it will send it out the extra two pins. The unit your using would need to be compatible with this and you'd need a 7 pin cable.
Haven't tried it myself.
