Home › Forums › Products › Rackmount › SPDIF coaxial output › Reply To: SPDIF coaxial output August 25, 2008 at 12:12 pm #117793 IDeangelis Hi Vincent you can either clock the Eclipse via S/Pdif or using WC. The easiest is S/Pdif. Under SETUP > DIG-IN set DIG_IN : RCA then set CLOCK: DigIn Hz. best I
