Home › Forums › Products › Rackmount › Erratic Midi Program Change › Reply To: Erratic Midi Program Change
August 25, 2008 at 12:17 pm
#117794
Hi Adam
I suspect:
-the AllAccess is a very advanced unit, with lots of features. It may be sending many MIDI commands at the same time. You need to eliminate the ones you don't need and channellize the others. Set Eclipse (and any other MIDI target unit) to a separate specific channel, rather than using OMNI (= Latin "ALL" = all channels).
-be aware of how MIDI Maps are created on Eclipse.
Map 1 recalls factory algorithms, from 100 to 227
Map 2 recalls user created & stored presets, from 0 to 99. You need to have presets stored in there for this map to work.
Map 3 recalls user presets stored to a card, from 500 to 999.
best
I
