Home Forums Products Rackmount analogue outs volume difference Reply To: analogue outs volume difference
#117871
 hi italo,
 -I have just upgraded the unit to 3.5b from 3.1 to see if that would help, but the level difference remains..
 -I can't remember what preset i noticed it on, most likely stringroom2
-Eclipse is connected to a mackie mixer – TRS from the mackie to XLR into the eclipse
 -signal in is an aux send from the mackie, my main channel on the mackie is an acoustic guitar–>lrbaggsparadi—>barber compressor—>line6effects
I have just returned from a festival, before which the eclipse was working fine..
 There was a power cut during my set (the stage was run from a generator charging batteries), I over ran a bit and the batteries ran out! I'm not sure if this is a variable, i have a surge-protected power 6-way which the eclipse plugs into..
Perhaps the eclipse has been knocked or vibrated during transit and so this is a hardware issue?
