Home › Forums › Products › Rackmount › Noise on Pitch Programs › Reply To: Noise on Pitch Programs
September 26, 2008 at 11:11 pm
#117889
Hi
I tried your suggestions, but no luck.I switched from balanced XP unbalanced TS, adjusted the levels, tried mono input instead of two channels. If mono is required, does the unused channel input o be turned off? Maybe noise is entering the pitch block and causing the problem. The noise will persist in a non-cyclic fashion even after all input has ceased. I will update the OS tomorrow. Again, has anyone else ever had this problem? Thanks.
