Home Forums Products Rackmount H8000FW: “Expansion Board init: E3” Reply To: H8000FW: “Expansion Board init: E3”
#117974
    The error code means that there is a problem with the FireWire interface board.
    It might be the result of a failed upgrade (if so, try the upgrade again), or it may be a hardware issue, in which case it will need repair.
